davidimurray
| posted on 24/4/12 at 08:29 PM |
Upper Ball Joint Covers - Zip ties ok?
Just knocked this up in the garage to cover my upper ball joints. Was thinking of putting some foam inside it and then drilling a few holes to pass
zip ties through to secure. Are zip ties an acceptable form of securing mechanism?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Daddylonglegs
| posted on 24/4/12 at 09:14 PM |
You need these
russbost
| posted on 25/4/12 at 07:38 AM |
We use a cable gland shroud cable tied in place, cheaper & simpler solution than the complete cover which has to be fitted prior to fitting the
ball joint, what you've pictured would be ok, but would need sharp edges covering.
Don't se there could be any quibble at IVA over what we use (there never has been) nor what you've made, their main requirementys are
durable, permanent & serviceable, cable ties are fine for a serviceable part.
davidimurray
| posted on 25/4/12 at 08:12 AM |
Thanks Russ
Do you have any photos of your setup you could post?
Dave
russbost
| posted on 26/4/12 at 08:36 PM |
Sorry, hadn't got any pics, have now uploaded one, but for some reason can't get the others to upload!
see below:-
