b3ngy
| posted on 20/6/12 at 11:34 AM |
holes in forward bulkhead
Can anyone give me some advice regarding the holes in the driver bulkhead for the brake and clutch pedal linkages.
Can they be left open or do you need to fit rubber boots over them (or something similar) in order to 'seal' the bulkhead up to pass iva??
Toprivetguns
| posted on 20/6/12 at 01:35 PM |
personally Id seal any holes through the bulk head to prevent moisture ingress.
Not sure on the IVA part.
Only drive as fast as your angel can fly... !
b3ngy
| posted on 20/6/12 at 01:38 PM |
Thats what i thought Andy.
Ive had a look through the iva but couldn't see anything.
Toprivetguns
| posted on 20/6/12 at 01:40 PM |
IMHO its always better to do a job properly and if you feel something needs doing don't hesitate.
Sealing any holes will not only make the install neat and tidy, it should reassure your IVA assessor you've implemented the same technique in
other areas he may not be able to see.
Tiger Super Six
| posted on 20/6/12 at 01:41 PM |
If a hot water pipe splits chucking boiling water on your legs, or if there is an engine fire, you will want every hole filled. Personally, IVA or not
I would make blanking plates.
Mark
Tiger Avon
b3ngy
| posted on 20/6/12 at 01:49 PM |
thats another reason why i thought of doing it mark
