johnemms
| posted on 21/6/12 at 10:40 AM |
VIN
What have you used to put your VIN on with?
Is this ok? comes with letter & number stencil..
New SEALEY E541 230V TUNGSTEN CARBIDE TIPPED TOOL ENGRAVER WOOD METAL GLASS 5051747603288 | eBay
Been punching samples onto box section - plate etc.. all deforms to *hite ..
[Edited on 21/6/12 by johnemms]
Ben_Copeland
| posted on 21/6/12 at 11:13 AM |
Punch onto a steel plate, then weld it on the chassis. That way you don't deform the chassis. Also do an alloy plate and rivet that on in a
different place too.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
matt_gsxr
| posted on 21/6/12 at 01:05 PM |
I did a similar thing with a dremel and it worked nicely and passed VOSA and DVLA with no comments.
Make sure you go deep enough (i.e. past the powerdercoat and into the metal).
Daddylonglegs
| posted on 21/6/12 at 01:44 PM |
Same as Ben said, I took a strip of 3mm to my local garage and they let me do the numbering and even signed the form to say it had been put on the car
(In case your not aware, the form is needed to confirm that the VIN is actually present on the car and needs to be signed/stamped by a garage and
is used for registration).
John
johnemms
| posted on 21/6/12 at 04:48 PM |
Strip of steel ..
Half a dozen goes..
Picked best..
Stitch welded on ... now clean up n paint !!
