Author: Subject: IVA Help Required - Paperwork
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 30/12/12 at 11:56 AM Reply With Quote
I'm just filling out the paperwork to apply for the IVA and I need some help;
Question 3t: What is the engine maximum power AND the engine speed at which it is obtained?
kw @ rpm
OR
bhp @ rpm
My engine in the Indy is a 2003 5PW R1.
Any ideas what I can answer for this question?
Cheers.
AndyW
posted on 30/12/12 at 12:13 PM Reply With Quote
according to the www the manufacturers rated power is 152.0 hp (113.3 kW) @ 10,500 rpm
but im sure other who have already done will be alone to correct me
sdh2903
posted on 30/12/12 at 12:43 PM Reply With Quote
Some have put a slightly lower rpm value than the actual figure. This is to assist in the noise test as its done at a percentage of peak rpm. I pinched maybe 500 rpm some lower it by much more. However if you have a pretty knowledgeable tester he may know what you're up to.
My carbed R1 went down as 150bhp @ 9500rpm and the tester never questioned it. I only just squeezed through noise test too!
adithorp
posted on 30/12/12 at 03:53 PM Reply With Quote
The required info is the max power rpm. In other words they want to know the RPM at which it makes max power. They use it to calculate the RPM to test exhaust noise at. Test is done at 3/4 max power RPM (or failing to know that 2/3 of max revs).
http://jpsc.org.uk/forum/
renetom
posted on 30/12/12 at 05:21 PM Reply With Quote
IVA
Hi
We put 147BHP @ 10,000 RPM
No probs
we have a 2001 R1
Good luck
René
