chris_smith
| posted on 15/1/17 at 08:22 PM |
Private plate
So if my donor is a T reg, and my kit gets an age related T reg then can I put a private plate on it up to a T?
Or can you not put private plates on kits?
snowy2
| posted on 15/1/17 at 08:25 PM |
as i understand it (i am going through the same process) if you get an age related plate its non transferable (so you cannot sell it on) but you can
buy and fit a private number..... its only a problem if you get a "Q" plate......in which case your stuck with it for the cars life.
sometimes you are the pigeon, most of the time the statue.
theduck
| posted on 15/1/17 at 08:28 PM |
as you have said, normal rules apply for an age related.
ReMan
| posted on 15/1/17 at 08:53 PM |
My understanding, same position as mine, is that you CAN PUT A PRIVATE PLATE ON
www.plusnine.co.uk
skydivepaul
| posted on 15/1/17 at 10:26 PM |
You can get some very cheap non age related northern Irish plates on eBay
I got RIG 2317 for my car last year after the previous owner wanted to keep the original plate on the car for £56 plus the transfer fee
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
| posted on 16/1/17 at 09:10 AM |
Never did it on my MK Indy (age related plate), but my understanding is you can change plates on a kit car unless it's Q reg, in which case I
believe the Q plate has to stay.
I've transferred plates on normal tin tops and it has to be said the DVLA aren't the sharpest bunch around. Last one I did on SWMBOs tin
top the DVLA website said "no" - for no apparent reason. I wrote to them and explained, they wrote back and said "no" - for
no apparent reason. Tried again online and it went straight through without an issue. Spares websites have since recognised the private plate
without hesitation as well.
Insurace? A slight bug-bear in that they tried to charge a £50 "admin" fee for the plate change. SWMBO got politely stroppy with them on
the phone and they backed off. Chancers? I think so.
ash_hammond
| posted on 16/1/17 at 03:43 PM |
I did it.
Bought a J plated sierra, got an age related plate and applied my private J prefixed plate with no issues.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
