Author: Subject: rear view mirror
jerry
posted on 17/1/05 at 05:38 PM Reply With Quote
rear view mirror
is a rear view mirror mandatory for the sva if you have two wing mirrors fitted.i drive a van at work and it has two door mirrors fitted, it also has a bulk head fitted behind the drivers seat so your field of vision is obstructed, it has no rear view mirror fitted, and its a white van !!!!!!
Chris_R
posted on 17/1/05 at 06:28 PM Reply With Quote
Sure it's come up before and AFAK providing you've got two wing mirror (on different sides of the car ) you'll be alright. Our work van's the same, white too.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
RoadkillUK
posted on 17/1/05 at 06:36 PM Reply With Quote
I believe that a centre rear view mirror is needed unless you cannot see behind you (eg. vans).
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
stevebubs
posted on 17/1/05 at 06:40 PM Reply With Quote
Yep. I believe the only exception (perhaps now done away with) is if you don't have a rollbar and the mirrors give you a perfect unobstructed view of behind you (i.e. no blindspots)
Conversely, I think that if the rollbar were to be made "solid" then a rear view mirror is unnecessary as there's nothing to look through. Bit OTT to avoid glueing a mirror to your screen if you ask me, though
theconrodkid
posted on 17/1/05 at 06:56 PM Reply With Quote
you do need 3 mirrors unless there is something to obscure the interior mirrors veiw
who cares who wins
pass the pork pies
Chris_R
posted on 17/1/05 at 08:22 PM Reply With Quote
I'll just keep quiet then.
posted on 17/1/05 at 08:25 PM Reply With Quote
I asked the SVA man well before my test - you do need a centre mirror. I pointed out that all I'd see was shoulders or the roll bar, but that didn't matter.
The only time you don't need one is if there's a solid partition behind you.
rgds,
andyace
posted on 17/1/05 at 08:37 PM Reply With Quote
If you dont have a windscreen just a deflector then where does it go !!!
stevebubs
posted on 17/1/05 at 09:04 PM Reply With Quote
Sportscar mirror mounted on the scuttle.
Lightning
posted on 17/1/05 at 09:52 PM Reply With Quote
I was told by SVA teater that you must have a centre mirror and an offside mirror. You must see I think 90% out of offsde mirror (ie the top of the wheel arch....so mount it high)
The centre mirror should see 60% (if I remember right). Mine didnt as my shoulder was in the way. If this is the case they ignore this mirror and move on to the nearside mirror if fitted. The same now applies as the offside.
All markers should be visible using one or both.
I asked did you have to have a centre one and was told you have to.
One of the vans I recently bought has blanked off rear windows but still was supplied with a centre mirror.
