BKLOCO
| posted on 7/11/05 at 03:46 PM |
Rear Fog Light???
I've seen a lot of discussion on the forum about the lens of the rear fog light having to be at 90 deg to the ground ie. vertical.
I have been looking at the SVA manual and cannot find where this is stated.
Am I simply missing it or is it not actually there and just an implied requirement? (Or even just one inspectorates interpretation?)
shortie
| posted on 7/11/05 at 03:56 PM |
In the lighting table in section 9.1 Annex 1 it says....
b. Vertical
i. 5°above and below horizontal.
HTH,
Rich
jos
Section 9.1 Lighting /signalling (March 2004)
Page 90 of the pdf version I'm looking at
Reasons for failure
5. A rear fog lamp
...... fitted such that the reflector is not facing squarely to the rear
BKLOCO
| posted on 7/11/05 at 04:13 PM |
I believe that the word vertical in this paragraph refers NOT to the fact that the lamp should be mounted vertically but that this is the plane that 5
deg above and below it must be visible.
b. Vertical
HTH,
Rich
BKLOCO
| posted on 7/11/05 at 04:15 PM |
I read 'squarely to the rear' to mean not pointing to either the left or the right.
Reasons for failure
5. A rear fog lamp
mookaloid
| posted on 7/11/05 at 04:22 PM |
At my SVA my fog lamp was pointing ever so slightly upward and he made me correct it so that it was pointing dead horizontally, or to put it another
way the lens had to be at 90 degrees to the ground.
Mark
shortie
| posted on 7/11/05 at 04:27 PM |
Basically it needs to be vertical, a number of people have failed on this before so best not to take a chance.
Rich.
