fesycresy
| posted on 20/3/06 at 08:27 PM |
R1 Clock Mounting
Has anyone mounted their clocks, R1 or other, outside the 127mm steering wheel limit and passed the SVA ?
If so, what did you use to comply with the 2.5mm radius ?
I've been told by a reliable source to use a hoover belt and temporarily fix it over the clocks, but I'm concered I'll get a
difficult examiner.
Cheers.
zxrlocost
| posted on 20/3/06 at 08:38 PM |
if you look at mine there within the radius and still look superb
fesycresy
| posted on 20/3/06 at 08:47 PM |
Does look good, but you've a straight bottom dash, mine drops down to the tunnel top. If I don't put it centre then it's going to
look off.
I may be able to get it directly behind the wheel, but I'd prefer it in the centre.
kev R1
| posted on 20/3/06 at 09:03 PM |
i was thinking exactly the same before i mounted mine, but put it bang on in the centre, don't think it looks too bad!! hope this helps a
little!
| posted on 20/3/06 at 10:04 PM |
We mounted both our Fireblade Clocks and ZX12R clocks in the centre of the dash, (not both on same car I hasten to add) so some fell outside the SVA
exempt zone. We made a plastic ring to fit over the dials with a > 2.5mm radius. I'll see if I can find a picture..............
Phil
| posted on 20/3/06 at 10:09 PM |
smart51
| posted on 20/3/06 at 10:23 PM |
Mine are not exactly central but look fine. They are just within the 127 mm of the sierra wheel. Look at the pic in my archive.
richijenkin
| posted on 20/3/06 at 10:52 PM |
mounted in the centre on a piece of bent alloy, then mounted the alloy to the dash from the back
