stevec
| posted on 8/5/06 at 04:06 PM |
Fuel tank level.
Other than a fuel gauge, what have you guys used to satisfy the SVA chap of your means of telling that the fuel tank is full? My filler is attached to
the top of the tank so you can see straight to the bottom of the tank.
Will a dipstick do for instance?
Cheers.
Steve.
| posted on 8/5/06 at 04:07 PM |
It is not a requirement for SVA, AFAIK
Peter M
| posted on 8/5/06 at 04:24 PM |
You have to present car for SVA with a full tank of fuel for weighing.As for a fuel gauge requirement not sure on that one.I would have thought as
long as you can see how much fuel you got in tank by looking through filler,this would be satisfactory.
my previous cars
my westfield build
graememk
| posted on 8/5/06 at 04:36 PM |
from what i understand you need a way of "seeing" how much fuel you have, so i supose a long stick would do, dip stick style, however
i'd want a guage in mine so i know when i'm going to run out.
Peter M
| posted on 8/5/06 at 04:43 PM |
quote: Originally posted by graememk
however i'd want a guage in mine so i know when i'm going to run out.
I would want a gauge in mine so that i could put fuel in mine before i ran of fuel.
my previous cars
my westfield build
stevec
| posted on 8/5/06 at 04:48 PM |
Thank for the replys, I have never had a fuel gauge on any of the motorbikes I have owned and I have never ran out of petrol, I wonder how many
people really trust their fuel gauges when they get down to the dreaded quater tank level. I have probably started one off now
RoadkillUK
| posted on 8/5/06 at 04:54 PM |
Tester just asked me if it was full and I said 'Yes'.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
zxrlocost
| posted on 8/5/06 at 05:49 PM |
its not an SVA requirement
r1 only has a low fuel light
muzchap
| posted on 8/5/06 at 07:28 PM |
Er comparing a BIKE FUEL TANK and a CAR FUEL TANK is a bit like comparing an Apple with a Pear
You can INSTANTLY tell if your bike has petrol or not - by sitting on it and leaning it from side to side - you hear the petrol - failing that remove
the cap and look in - conveniently located.
On a car - undo harness, out of seat, check fuel level, back in seat, re-do harness - i should imagine it would get very tiresome
But hey - your car, you do what ya wanna - that's the beauty of it
[Edited on 8/5/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
stevec
| posted on 8/5/06 at 08:14 PM |
Cheers, I will.
| posted on 8/5/06 at 08:31 PM |
Just fill the tank with fuel and set the trip. Take a small jerry can of fuel with you. Hammer it everywhere you go and see how many miles it does on
a tank full of petrol. Use the mileage as your gauge. So long as you set the trip every time you fill up, it ain't a problem.
Phil
stevec
| posted on 8/5/06 at 08:35 PM |
Cheers Phil, Thats about what I have planned.
The times I will be doing longish journeys wont be that often anyway,
All the best,
Steve,
| posted on 8/5/06 at 08:41 PM |
We used that method to good effect with the Blade engined Indy. This ZX12R engine is a bit more posh though and comes with a fuel level display.
