RichieC
| posted on 1/6/06 at 09:05 PM |
Harness Bolts/Mounts
Hi all, After having to buy some 7/16 taps to clean the threads of powdercoat, I found this is as far as the bolts screw in. Theyre not the 2"
ones or anything so theyre not bottoming out. I think thats just as much thread as there is.
Question is, is it an SVA fail? I can certainly see how it could be argued the threaded portion of the bolt would snap rather than be supported by
the shoulder.
Thoughts/opinons?
TIA
Rich
muzchap
| posted on 1/6/06 at 09:11 PM |
How about a washer?
You can't leave it like that - but nipped up on a few washers it will be fine.
I'm having to do that on mine - to make sure they line up properly.
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
RichieC
| posted on 1/6/06 at 09:12 PM |
Yeh - I think washers are the solution - bit of a PITA though.
Theres no way Im going to drill further to retap it deeper cos the drill is sure to wander and wreck the existing threads.
Rich
flak monkey
| posted on 1/6/06 at 09:22 PM |
Just chop the end of the bolt off
Sera
http://www.motosera.com
Deckman001
| posted on 1/6/06 at 09:24 PM |
You sure your not building a Locost ???
Jason
RichieC
| posted on 1/6/06 at 09:25 PM |
lol
Im not going to attack the bolts. Theyre not overly long anyway.
RazMan
I would chop off 5mm - sorted
Raz
RichieC
| posted on 1/6/06 at 09:26 PM |
I agree that would look better but not really great when the chassis and bolts are from the same supplier.
8.8 grade are going to be a giggle to cut anyway
Rich
flak monkey
| posted on 1/6/06 at 09:27 PM |
A thread should engage for a minimum of 1.5times its length IIRC. Just chop a couple of mm off the end of the bolt. they will be fine, and the SVA man
wont bat an eyelid.
8.8 grade bolts cut easy
[Edited on 1/6/06 by flak monkey]
Sera
graememk
| posted on 1/6/06 at 09:29 PM |
i had to shorten mine. grinder wheel.
muzchap
| posted on 1/6/06 at 09:34 PM |
Er whats wrong with washers? No cutting or messing around?
They look neat as well? - if you wanted you could even paint them so they blend in?
Very 'destructive' bunch of people you lot are - hacking things to pieces isn't the only option
RichieC
| posted on 1/6/06 at 09:37 PM |
heh - Washers are the quick and easy fix, I cant see why Mr SVA wouldnt approve.
Richie
RazMan
| posted on 1/6/06 at 09:43 PM |
Any excuse to get the new angle grinder out
Raz
Marcus
| posted on 1/6/06 at 09:44 PM |
I don't think the washers will be a problem, but those mounts look a little 'spindly'. Are they braced in any way?
Marcus
Marcus
Because kits are for girls!!
RichieC
| posted on 1/6/06 at 09:47 PM |
No theyre not braced but were only talking 1.5" or so, the camera was on macro so they look really tall.
Richie
muzchap
| posted on 1/6/06 at 09:50 PM |
LOL @ RazMan - at least you honest
I must say they are addictive! I got a great deal from Wickes
A drill, jigsaw and angle grinder for £40.00
I've hacked plenty of things with the angle grinder
