davrus
| posted on 20/8/06 at 08:19 PM |
locost weight
Nearly forgot to ask , what shall i put down on the weight of my locost on the s.v.a form , it is a 1300 cross flow
Thanks again
nitram38
| posted on 20/8/06 at 08:59 PM |
You only have to put down axle 1 & axle 2 design weights.
This is not the actual weight. If you put down 450kg per axle, you won't be far wrong. They can be over the actual design weights, but if under
the tester will ask to see paperwork from the manufacturer to change them.
In other words you will get a fail.
wicket
| posted on 21/8/06 at 10:43 AM |
On the form we put design weights as 450kg front and rear, gross weight 900kg.
At SVA actual weights with all fluids but without driver was 308kg front and 304kg rear.
