StevieB
| posted on 30/8/06 at 11:57 AM |
P-clips - Type and spacing
Hi.
Before I fit my brake/fuel pipes, are there any SVA ptfalls to be had using plastic p-clips rather than rubber lined alloy items? Also, what entres
should the clips be at?
I have purchased the latest SVA book, but it's not clear as to what they're looking for in terms of materials, just that the pipes are
supported at regular intervals (I was thinking 200mm to be safe, but the fewer the better if I can get away with it)
cryoman1965
| posted on 30/8/06 at 12:18 PM |
300mm is the max spacing.
I used plastic p-clips on some of my pipes and it was fine.
scoey m
| posted on 30/8/06 at 01:20 PM |
Hi mate
ive used plastic p clips for both fuel and brake which where supplied in kit + my build manual states no more than 6 inches from clip to clip
hope this helps
regards
DavidM
| posted on 30/8/06 at 02:33 PM |
I used plastic P clips for brake and fuel lines and spaced at 8" centres. Passed OK.
Maximum is 300mm but I went for closer spacing because it worked out best aesthetically and was much more secure. Only used a few extra clips.
Proportion is Everything
| posted on 30/8/06 at 02:42 PM |
I put mine a hand-span apart - roughly 220mm according to my ruler!
In some places I varied this a little bit, to get even spacing along a particular part of the chassis (all part of the 'impress the
tester' bullsh*t).
StevieB
| posted on 30/8/06 at 03:07 PM |
I'm going with a 'less is more' approach to my build, and this counts right down to the amount of p-clips I want to use - working on
the basis that just enough to get by is perfect, but any more than that is over engineered.
SVA doesn't make this principle very easy to stick to though!
Danozeman
| posted on 30/8/06 at 04:01 PM |
All mine is clipped with plastic p clips about 25mm apart. Havent had it tested yet but im sure it will pass.
Dan
StevieB
| posted on 30/8/06 at 04:48 PM |
I suppose if the standard says max 300mm and you go with 299mm, you'd still pass (will it help to hide a chocolate digestive or two for the
tester to find?)
iank
| posted on 30/8/06 at 05:01 PM |
Really? 1inch spacing? or is that a typo for 250mm?
StevieB
| posted on 30/8/06 at 05:02 PM |
I assumed typo - either that or a hell of a lot of p-clips (new sport - Xtreme SVA!)
iank
| posted on 30/8/06 at 05:26 PM |
With events like:
"night before panic padding the sharp bits"
"spirit level adjustment of fog lamp to vertical"
"stuffing bits of perforated steel up the exhaust"
with the highlight event of the "2 hour sweat"
and of course the final event of:
"pulling off the uglier bits of padding"
StevieB
| posted on 30/8/06 at 05:28 PM |
I'm betting there's a 3 mile radius around every SVA centre where all hedgerows and ditches are full of foam pipe lagging covered in black
nasty tape and bits of radius'd balsa wood!
