| posted on 2/9/06 at 10:33 AM |
s.steel braided hoses again.
seems like the only hoses that are SVA approved are the ones with crimp type connection; these can be rubber or stainless steel.
the type that use olive and nut type fittings are not ok.
Guess which ones I have fitted after removing the rubber hoses?
Bu88ery and bo77ocks is what springs to mmind,.
Anyone can please confirm this before I once again get covered in brake fluid
cct7kitcars
| posted on 2/9/06 at 10:44 AM |
you are correct about the olive type not been alowed for the sva but i have had 2 cars pass with them fitted dont think the tester realised
joe
cct7kitcars
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
| posted on 2/9/06 at 10:51 AM |
mine is at L.Buzzrd - what chance have I that the inspector will not reliase? They are covered with convoluted tubing that can ofcourse be moved.
Statistically I'm bound to fail but if all passes excpet the oses, then that would be annoying.
Qurestion is, do. I feel, luck, well do I?
(guess I'm gonna have to tame 'em off.)
craig1410
| posted on 2/9/06 at 12:10 PM |
I have made up my hoses using Euroquip hoses from Rally Design. As far as I understood, these were supposed to be okay for SVA as they have an inner
metal supporting tube against which the olive could compress.
Have I missed some change/clarification in the rules?
Craig.
ps. Here is a link the RalDes page:
http://www.rallydesign.co.uk/catalog/index.php?cPath=85_248_249
cct7kitcars
| posted on 2/9/06 at 12:11 PM |
the sva classes comprestion joints on a braking system a fail
craig1410
| posted on 2/9/06 at 12:22 PM |
There seems to be a bit of inconsistency about that and many people have passed just fine using the compression fittings, provided they have an inner
supporting sleeve. The SVA manual section 16.4a specifically states that,
"Compression joints of the type using separate ferrules are not considered suitable for joints on hydraulic brak lines other than in the case of
a hose designed for a high pressure application that incorporates an inner support sleeve in the compression fitting"
Mark Allanson for example passed just fine with Euroquip connectors.
I for one will take my chances at SVA 'cause I'm damn sure I ain't going to re do the whole car unless I absolutely have to...
Craig.
StevieB
| posted on 2/9/06 at 01:28 PM |
Hi.
Being a fool, I've purchased the SVA Manual - it states as follows:
'Compression joints of the type using separate ferrules are not considered suitable for joints on hydraulic brake lines other than in the case
of a hose designed for a high pressure application that incorporates an inner support sleeve in the compression fitting'
I'd say that if you don't have inner support sleeves fitted, don't fill the brake fluid yet!
Could have saved a whole load of typing there too!
[Edited on 2/9/06 by StevieB]
