Author: Subject: Reverse Light
ash_hammond
posted on 7/1/07 at 01:18 PM Reply With Quote
Reverse Light
Hi Chaps
Question regarding a reverse light?
On a normal MOT the tester will not fail a car if the reverse light is inoperative, so.... does not mean it does not need to be there for an SVA? I presume it does since all the cars i have seen going for an SVA have them fitted.
Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
nitram38
posted on 7/1/07 at 01:23 PM Reply With Quote
No reverse requirement for sva or mot.
iank
posted on 7/1/07 at 01:35 PM Reply With Quote
But the MOT tester should fail if it is fitted but not working.
ash_hammond
posted on 7/1/07 at 01:52 PM Reply With Quote
no - i have taken cars for MOT test before with no reverse light working and its passed.
Ash
stevec
posted on 7/1/07 at 02:07 PM Reply With Quote
Ash
Confirmed.
Steve.
[Edited on 7/1/07 by stevec]
davrus
posted on 7/1/07 at 02:50 PM Reply With Quote
i am an m o t tester and i can say that a reverse light is not even tested in an m o t , so even if it has one and it dosnt work it is not a failure.
Good luck
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
iank
posted on 7/1/07 at 03:14 PM Reply With Quote
Interesting, every other time this has been asked this has been taken as the correct answer.
I've certainly been failed on it many moons ago (wasn't the only thing) and looking at the web there is a reference to it seemingly being to be down to tester discretion, presumably under one of the 'unsafe' catch-alls.
davrus
posted on 7/1/07 at 03:54 PM Reply With Quote
Nothing is down to tester discretion , there is the same rule book book for all testers with the same failure items , + you try finding a failure for a reverse light on the m,o,t computer it simply is not part of an m.o.t as is front fog lamps not a testable item.
[Edited on 7-1-07 by davrus]
posted on 7/1/07 at 04:25 PM Reply With Quote
Our reverse light doesn't work, but that's cos it hasn't got one. The reason it hasn't got one is because we have no reverse gear. Passed SVA...
graememk
posted on 7/1/07 at 05:37 PM Reply With Quote
i had one all wired up then found out the switch in the gear box dosnt work, so now i have 2x fog lamps lol
jollygreengiant
posted on 7/1/07 at 06:00 PM Reply With Quote
You could fail a reversing light I would think under only two conditions.
1. It being permanently lit or illuminates when primary lights are on, thus showing a white light to the rear. MOT fail
2. The lights housing being so damaged that it proved to be dangerous to anyone walking past the vehicle during their normal business.
Other than that it is non testable.
posted on 7/1/07 at 06:53 PM Reply With Quote
They can be too bright as well, there's a limit on the bulb size
