Author: Subject: dash
minipete
posted on 17/2/07 at 08:15 PM Reply With Quote
dash
Hi, i'm new to this SVA lark so am after a bit of advice. Does anybody know if this style dash would be suitable to pass an SVA.
It's fitted into a mini minus shell.
Many thanks
Pete
Mark Allanson
posted on 17/2/07 at 08:20 PM Reply With Quote
I think they will want to see dials and switches , and a steering column may be of advantage.
Looks ok apart from the radius at the bottom, needs to by 38mm diameter from memory
Bob C
posted on 17/2/07 at 11:13 PM Reply With Quote
The non- radiused bit you can see might be in the steering wheel exempt area, the nearside looks to have a radius but dunno if its the 19mm required. The brackets on the cage look decidedly sharp & I fear the gear knob is a definate fail . Also some of the screwheads on some plates look like fails
Bob
COREdevelopments
posted on 18/2/07 at 12:50 PM Reply With Quote
have you any more pics of your build as i love minis and love the minus' too, aint seen many.
thanks
minipete
posted on 18/2/07 at 06:32 PM Reply With Quote
Thanks for the help. The screw heads on the floor plates are all button headed bolts for allen keys. If I fill the allen key hole then will they pass or would I be better to hide the plates under the carpet. I intend to put plastic covers over the gear lever bolts and will now fit a round gear knob.
The brackets on the cage are for the door bars.This is a pic of them fitted so do any of you think the bracket will still be a problem
This is a pic of both the minus's i'm building/built. The green one was already a complete car before I converted it to use an R1 engine so didn't have to have an SVA. The other one is a new build and it's causing a few headaches trying to get it right.
Unfortunately neither belong to me
