flak monkey
| posted on 14/3/07 at 09:59 PM |
VIN Plates
Yes, its getting to that time of the build.
I can get the plates dot matrix etched at work, but...
The VIN needs to be on 2 places on the chassis according to my DVLA man.
So is 2 under the bonnet ok? One will be a stainless plate welded to one of the chassis rails, the other will be an alumiunium plate riveted onto the
scuttle firewall.
Any one see any problems?
Sera
http://www.motosera.com
blakep82
| posted on 14/3/07 at 10:02 PM |
I would suggest (for no other reason than it seems silly putting them both together) er, yeah, well seperate them. one in the back by the fuel tank
perhaps, or in the passenger footwell? somewhere less obvious?
________________________
locoboy
Welding stainless to mild steel?
Can that be done?
Locoboy
flak monkey
Can that be done?
Yep, with a TIG it can
[Edited on 14/3/07 by flak monkey]
Sera
locoboy
| posted on 14/3/07 at 10:04 PM |
I see no problem then apart from maybe as already said putting one out of sight,
or even going as far as a 3rd one hidden for potential 'post theft' identification god forbid
Locoboy
matt.c
New toy flak?
NS Dev
| posted on 14/3/07 at 10:13 PM |
Can that be done?
Can be done with any welder you car to name!!
You use stainless rods to weld any steels of unknown origins in fact
matty_64
| posted on 14/3/07 at 10:34 PM |
dvla stated on my letter chassis was to be marked on bodywork & on a plate attatched to the vehicle.the number should be stamped/embossed on the
o/s in a clearly visible & accessible position.hope this helps,ive welded a plate on the chassis & rivetted another to the scuttle
nitram38
| posted on 14/3/07 at 10:47 PM |
Strange, the tester only looked and asked for one number and it was stamped directly in the chassis.
I do have another hidden one on the chassis that only I can point to it necessary.
wicket
| posted on 14/3/07 at 10:51 PM |
Another DVLA anomaly, mine's on once stamped in the chassis rail under the nose cone, can only be read with the bonnet removed.
| posted on 15/3/07 at 10:03 AM |
this is another one of the ill defined areas that seems to vary where and who you ask.
I can only comment on my case;
a) ali plate pop riveted to scuttle in the engine bay - semi-permanent
b) number stamped on the chassis on top rail near the radiator (again in engine bay) permanent can only be ground off.
