COREdevelopments
| posted on 17/3/07 at 03:20 PM |
is this ok for Mr sva??
i want to put my coil on the back of the engine just above the bell housing, but if you look in the pic below, is it too close to the fuel
filter/regulator, and would it pose a threat to Mr sva? what do you think?
[img]/upload/170307_1504~00.jpg[/img]
[Edited on 17/3/07 by COREdevelopments]
COREdevelopments
| posted on 17/3/07 at 03:23 PM |
pic
stevebubs
| posted on 17/3/07 at 03:24 PM |
Standard place for a zetec installation (engine conveniently comes with a bracket for the job).
So long as everything is routed ok and not interfering then I can't see him having an issue.
Stephen
(above statement is an educated guess so willing to be corrected)
COREdevelopments
| posted on 17/3/07 at 03:29 PM |
thats why i would like it to be positioned there as i can use the original leads that came off the zetec along with the coil. i will be routing the
wire away from the fuel pipe as dont want them too near.
thanks for the fast reply.
rob
russbost
| posted on 17/3/07 at 05:01 PM |
Providing it's all nailed down then no probs for SVA
COREdevelopments
| posted on 17/3/07 at 07:50 PM |
ye it will all be on decent brackets, was just refering to location as it is near the fuel reg. thanks guys
rob
craig1410
| posted on 17/3/07 at 08:37 PM |
Yep, should be okay as long as it doesn't touch even if the engine rocks a bit. I'd knock the corners off the bracket as this will buy you
another 1/2" by the looks of it.
I'm assuming that you will tie down the loose wires.
Craig.
COREdevelopments
| posted on 18/3/07 at 11:28 AM |
yes everything will be secured down as it should aint even done the wiring yet. thanks for the info guys
atb
rob
