mike smith1
| posted on 12/4/07 at 08:24 AM |
SVA Help
Hi guys
Couple of points after my post of pre sva pics:-
http://www.locostbuilders.co.uk/viewthread.php?tid=63673&contribmessage=none
The braided hose covering, can i use the spiral rubber wrap that tifosi sell or does it have to be a solid cover?
The Battery isolator key was mentioned that it could be a problem, i thought it would be ok as its behind the dash and fairly high up.
Mike
shortie
| posted on 12/4/07 at 08:28 AM |
I used the spiral wrap to cover my braided hoses and it was no problem.
Can't see any reason why your cutt-out should be a problem, there is something about not being able to operate when driving but to be honest
you'll probably be fine so I would leave it where it is.
Just had a quick look at the other post, are you fitting under dash panels?
Rich.
[Edited on 12/4/07 by shortie]
stevec
| posted on 12/4/07 at 08:35 AM |
I also used spiral wrap with no comments from the tester. make sure you get enough on so it dosn't walk up the hose when youturn full lock.
all the best.
Steve,
fesycresy
| posted on 12/4/07 at 11:48 AM |
I was about to be failed at Nottingham for having the second form of immobilisation in the car.
I quickly unscrewed it (only a toggle switch, connected to the sidestand safety) and cable tied it to the rectifier in the bay / tunnel.
But I've heard of plenty of people passing with the second form of isolation within the car ??
