Brooky
| posted on 28/7/03 at 05:24 PM |
Its Passed
Passed sva on monday 21st with a few minor fixes to be done (not enough sticky foam on the inside mostly) got an age related plate - brand new
Happy as larry at the minute.
mr loo
| posted on 28/7/03 at 05:58 PM |
Well done
Had a look at your photo's ,car look's mint
Viper
| posted on 28/7/03 at 05:59 PM |
Well done that man
Brooky
| posted on 29/7/03 at 09:48 AM |
some photo's of the finished car have been uploaded, cheers for the support.
andyd
| posted on 29/7/03 at 10:18 AM |
Is that a quik-releasable wheel?
Any chance of a close-up pic?
I'm specifially interested in how you made the horn work. I'm assuming it's the coil wire going into the dash.
Did the SVA inspector question the steering wheel at all?
Brooky
| posted on 29/7/03 at 03:37 PM |
Andy , yes the wheel is quick release but no the coiled wire is for the push button gear change on the wheel, not the horn.
Interestingly enough you dont need a horn for the sva.
All i did for the sva was stick some sticky foam over the metal centre of the whell and it passed.
Do you still want the close up ?
mr loo
| posted on 29/7/03 at 09:22 PM |
Hi Brooky
Where can i get an aeroscreen like your's?
How much did it cost?
And did it pass the sva with it on?
cheers Ian
andyd
| posted on 30/7/03 at 08:15 AM |
No that's ok.
I've looked in your photo archive at the dash pic which has the wheel on. I was just interested in what you'd done for the horn but I see
you've done nothing.
I wasn't aware that no horn was ok for SVA. I'll leave mine off and fit a nasty really sharp button to the wheel for it after the test!
Where did you get the quick release oojamaflip? (tech term!)
Brooky
| posted on 30/7/03 at 12:39 PM |
Mr Loo the aeroscreen came from stuart taylor motorsport and I think it was 60 +vat
Andy it has got a horn its the little red button to the right of the temp gauge, but shall be moved shortly in the post sva deluge of work.
And the quick release thingymyooja came from rally design i think.
[Edited on 30/7/03 by Brooky]
andyd
| posted on 30/7/03 at 05:39 PM |
Cheers Brooky, Rally Design is where I was going to get mine from.
I guess the coiled wire jobby could be used for the horn too? If so where did you get that from and how many connections does it have?
TIA
mr loo
| posted on 30/7/03 at 08:49 PM |
Cheer's
Brooky
| posted on 30/7/03 at 09:03 PM |
The coiled wire came with the klicktronic gear change system as did the connector but you can buy the connector from maplins (mine has 4 pins but you
can get others)
