Dave Bailey
| posted on 1/5/07 at 08:51 PM |
Fuel Line mounting
Hi!,
Plan to attach some small brackets in the tunnel to mount my fuel line per the attached photo. Anyone see a problem with this method for SVA?
Plus where have people routed the tubes through past the diff? all seems a bit tight!
  fuel line mounting bracket
SeaBass
| posted on 1/5/07 at 08:59 PM |
Yep I think your fuel lines are a bit short...
On a more serious note - will the inspector pass those as a permanent method of fixing the fuel line. They could argue that the tubing could come
loose from the 'clip'
Dave Bailey
| posted on 1/5/07 at 09:03 PM |
the clips are from a standard production car so I thought they would be o.k.!
graememk
| posted on 1/5/07 at 09:10 PM |
i have those in my tunnel, passed sva ok.
Dave Bailey
| posted on 1/5/07 at 09:26 PM |
thanks for the info!
What is with the ISP thingy?
dave1888
| posted on 1/5/07 at 09:31 PM |
Are the fuel lines rubber i thought the fuel lines had to be run in copper?
| posted on 2/5/07 at 07:10 AM |
rubber fuellines are ok as long as they have written on them that they are suitable for fuel.
Dave Bailey
| posted on 2/5/07 at 11:12 AM |
these are nylon
Bluemoon
| posted on 2/5/07 at 01:01 PM |
You could'nt use those clips for rubber, it will have to be a hardline of some-sort, Nylon should be o.k. you could take a pic of set up in a
production car to show SVA man it's excepted practice...
Dan
