The Doc
| posted on 13/7/07 at 09:24 AM |
Security device
What constitutes an acceptable security device?
Ignition key switch
Steering lock
Both
Ta
Mike
graememk
| posted on 13/7/07 at 09:25 AM |
mine past sva with steering lock and ing key
matt_claydon
| posted on 13/7/07 at 09:30 AM |
Yes, ignition switch and steering lock are counted as two separate devices.
DarrenW
| posted on 13/7/07 at 09:45 AM |
i junked Sierra switchgear and had the upper column bearing casting machined and polished - ie no steering lock.
I passed with a key switch on dash (that you turn before pressing start button) and a transponder type immobiliser. just to give you an option.
I think others have passed with a battery cut off switch under the bonnet as one of the devices too.
| posted on 13/7/07 at 12:10 PM |
Yup. I passed with an ignition switch and a battery immobilizer hidden away. There was discussion about whether the battery cut-off should or
shouldn't be reach-able from the driving position for it to count (ie if its stuck in the engine bay you're unlikely to use it but if its
too obvious its hardly a security device)...
worX
| posted on 13/7/07 at 02:32 PM |
I passed with ignition key and fuel pump immobilisor switch
Angel Acevedo
| posted on 14/7/07 at 03:48 PM |
mcMaster Carr in US carries high security switches that can be wired to cut ignition only or fuel only.
That way even if the burglar manages to make the engine turn, the out of sight switch will prevent from running.
check page 827 for figure...
