dirty130
posted on 17/7/07 at 05:27 PM |
circlips
hello, I have forgot to put the circlip on the speedo drive and i have paneled up the car. I have now removed the panels but it is well hard to get
the right circlip into the housing. Does any 1 have a picture of the circlip or know the size thanks
It will fit wheres me hammer?
posted on 17/7/07 at 06:18 PM |
I don't know the size - but I know your pain...
I made a 2" hole in the tunnel side panel for the sole purpose of getting at the speedo drive. Normally it has an ali panel pop-riveted over
it, but it can be removed fairly easily if I have further problems.
Good luck!
dirty130
posted on 19/7/07 at 06:51 AM |
circlips
stuff the circlip last night i got fed up and drilled and tapped a 5mm hole put a bolt in and loads of loc tight job done!
posted on 19/7/07 at 09:25 AM |
I lost the original and found one that was a bit too big. I cut one end off it and it went in easily , I hope it comes out the same.
dirty130
posted on 19/7/07 at 04:29 PM |
circlip
my mate managed to get 1 that fitted but then it came out while driving. so he had to take the body panels off his totaly finished car.
