saigonij
| posted on 22/7/07 at 05:46 PM |
flasher/hazzard relay noise
for the sva, should the indicators have a clicking sound when flashing? i have an electronic one and its silent....
blakep82
| posted on 22/7/07 at 05:49 PM |
they have to make a noise... i guess you could fit a buzzer to the indicator light on the dash
________________________
saigonij
| posted on 22/7/07 at 05:55 PM |
what can i do to add a noise? a buzzer? can you buy "clickers" ?
nitram38
| posted on 22/7/07 at 06:02 PM |
Just rechecked the sva manual: either an audible or visual tell tale is required.
If visual, should be within the view of the driver
[Edited on 22/7/2007 by nitram38]
saigonij
| posted on 22/7/07 at 06:09 PM |
ok, so as long as i have dash board lights then thats ok?
does anyone know where i can get a clicker component from just in case?
| posted on 22/7/07 at 06:18 PM |
Just get a small buzzer; couple fo quid tops; from Maplins or similar. Mounted in series as it's easy not to see the warning lights and adding a
little noise is a helper.
nitram38
| posted on 22/7/07 at 06:33 PM |
If you have a visual tell tale then an auldable one not required.
Do yourself a favour and download a copy of the sva manual.
It took me all of 30 seconds to find the answer......something you could have done and probably quicker than getting the wrong answer from other
people who are just guessing!
saigonij
| posted on 22/7/07 at 06:47 PM |
where did you down load a copy from?
nitram38
| posted on 22/7/07 at 06:54 PM |
I can't remember where I got mine as I did a search on google about 18 months ago and I found it quite quickly.
I am sure if you put a post asking for the same, then someone else might have the actual link.
nib1980
| posted on 22/7/07 at 06:55 PM |
try here
http://www.rootpeg.net/SVAMarch2004.pdf
nitram38
| posted on 22/7/07 at 06:57 PM |
try here
That's a good'en !
DIY Si
| posted on 22/7/07 at 07:20 PM |
Is that the latest version, as applies to us/kit builders? I know they have regular updates, but haven't heard about anything special.
Sun Tzu, The Art of War
nitram38
| posted on 22/7/07 at 08:03 PM |
It has not changed much. Go to the vosa website for a few minor updates.
RazMan
| posted on 22/7/07 at 10:00 PM |
Ref indicator warnings - you do not need an audible warning of any kind, just a flashing light.
Raz
nitram38
| posted on 22/7/07 at 11:04 PM |
It is either one:
RazMan
| posted on 23/7/07 at 04:55 PM |
I stand corrected - just the hazards that need a light then
[Edited on 23-7-07 by RazMan]
Raz
