chrsgrain
| posted on 7/8/07 at 09:23 PM |
Cycle wing SVA rules...
Hi all,
can anyone help with a simple explanation of what the cycle wings have to cover at the front... I've got an SVA manual, but can't decypher
the legalese...
Done a search but no joy - could have sworn there was a thread about it??
Chris
James
| posted on 7/8/07 at 09:36 PM |
Briefly:
Just make sure the front of the wing is in front of the rim of the wheel (not tyre). Use a plumb bob or summat to check.
And make sure the side of the wing overhangs the side of the tyre.
And cover the edges of the wing with 'U' trim.
HTH,
James
- Muhammad Ali
JohnN
| posted on 7/8/07 at 09:50 PM |
Plus............
The rear end of the wing must finish below the horizontal centreline of the wheel
[Edited on 7/8/07 by JohnN]
DavidM
| posted on 7/8/07 at 09:59 PM |
Sorry, but there is no requirement for this in the regs.
It may be required by certain SVA centres as "their" requirement, but it aint in the regs. Discussed on here loads of times.
quote: Originally posted by JohnN
Plus............
DIY Si
| posted on 7/8/07 at 10:03 PM |
What he said. It's seen as a requirement by some centres, but it's not in the rules, just the leading rim edge and width.
Sun Tzu, The Art of War
craig1410
| posted on 7/8/07 at 10:10 PM |
I thought the rear of the cycle wing had to cover the tyre when viewed from directly above. In other words if you bring a set square up behind the
tyre it must touch the cycle wing before it touches the tyre.
I agree with the front of the cycle wing having to cover the rim when viewed from above.
Craig.
| posted on 8/8/07 at 07:16 AM |
I'm with Craig...
The picture below shows one of my front wings - this has passed SVA with no comment. I even took the picture to the test centre prior to my test, just
to check!
  Wheel side
You'll see that the front is in front of the wheel rim, and the back is behind the back of the tyre.
HTH,
chrsgrain
| posted on 8/8/07 at 08:13 AM |
OK - thanks for that guys, the arches will be fitted today!
Chris
