vindicator
| posted on 20/8/07 at 03:04 PM |
brake master cylinder/reservoir pipes
Hi All,
Failed the SVA last Thursday on 13 points, all minor ones.
The one that I would like some info on it the pipes from the brake reservoir to the master cylinder. The white marking had rubbed off mine and Mr SVA
wanted info on the pipes used. I have got some reference numbers off the pipes which I have at home and will publish later once I get home. Does
anyone know what pipes should be used, is there a set standard or reference number that is used. I don't mind changing the pipes as it should
only take 10 mins to change. Is there a site that lists pipes reference numbers...should the pipes be lower pressure ones.....
Regards
TimR
wicket
| posted on 20/8/07 at 03:21 PM |
Mine are Fiat Seicento hoses.
A couple of pictures in my archive of marked hoses. The longer one is p/n 46774776, 290mm long, and the other is p/n 46774775, 220mm long. Total cost
£8.48 inc vat.
If I had known I would have just bought 2 of the shorter ones, they are just the right length.
RazMan
| posted on 20/8/07 at 03:23 PM |
They need to be designed for low pressure brake fluid and will have a cotton braided cover. Ideally you need to ask the supplier to include a
certificate which states it is ok with the part number printed on the hose.
Raz
COREdevelopments
| posted on 20/8/07 at 05:22 PM |
i am in need of some hose too, and i have noticed that the toyota previa(latest type) has these pipes but are not braided. if they are good enough for
manufacturers surely its god enough for sva?
rob
vindicator
| posted on 20/8/07 at 07:05 PM |
got some photos of the labeling on the pipes going to the master cylinder.
Seems as the pipes are made in USA (they came with the master cylinder and reservoir from the kit manufacturer). The number is CS072405 D100 and is
upto 200psi.
If anyone can give me any info on the pipes I would be greatful.
  Brake hose
  brake hose 2
[Edited on 20/8/07 by vindicator]
vindicator
| posted on 29/8/07 at 09:01 AM |
found out that the pipes are made by gates from USA, waiting for specification to be emailed back to me.
An update as I can't add a new reply here.....the specification did not arrive so I hunted down some new pipes that dealt with brake fluid and
had an email from AP racing saying so. I did phone everyone in yellow pages under piping / hydraulic / brakes etc, even auto part suppliers featured
in car mags and they could not help. Speaking to everyone about this, this is a big concern and a majority of cars fail SVA because the pipes used
can't handle brake fluid, even fuel marked rubber pipes can't be used. So if you are after brake fluid pipes between the reservoir and
master cylinder, try APRacing.
[Edited on 31/8/07 by vindicator]
MikeR
| posted on 12/2/08 at 12:26 PM |
I've just asked a similar question.
Demon Theives do some - but its not obvious when you search for it online, i think its push on hose brakes finds it.
| posted on 12/2/08 at 07:18 PM |
Think Automotive sell the correct hose. Been covered loads of times. Would put in link if I knew how but if you do a search you should find the info
you need
matt_gsxr
| posted on 6/4/09 at 09:19 PM |
HI there,
I used all the numbers to search the Gates site,
Here is a link to the relevant page, it does include EPDM, but I don't know whether this is adequate for the SVA man,
Gate Adapta Flex link
