joolsmi16
| posted on 9/9/07 at 09:41 PM |
water level
Hi all, is it a sva requirement to have a min/max level indicator on a header tank or warning switch/light.
As none of the aluminium types have a level indicator on them.
graememk
| posted on 9/9/07 at 09:47 PM |
no
you dont even need water in the engine
as long as it runs for long enough lol
edit
i wouldnt advise turning up for sva with out coolant.
[Edited on 9/9/07 by graememk]
rayward
| posted on 9/9/07 at 09:52 PM |
ebay tank
with level indication
hth
Ray
blakep82
^unless you're using an air cooled engine...
________________________
nitram38
| posted on 9/9/07 at 10:05 PM |
I am using a rover plastic expansion bottle with a level sensor and a light on my dash.
RazMan
| posted on 9/9/07 at 10:37 PM |
The only level indicator you need for sva is the brake fluid reservoir - everything else is purely up to you.
Raz
