Author: Subject: specifications (data sheet)
copeo
posted on 14/9/07 at 11:01 AM Reply With Quote
Hi, i need your help!
i'm trading for a locost bec and to register this car in italy i need:
- MOT valid
- V5 or V5c or V561
- Specifications
the seller hasn't the specifications of the car, where i can find this document? from the manufacturer?
cheers.
Sorry for my english!
[Edited on 14/9/07 by copeo]
www.allkitcar.com
posted on 14/9/07 at 11:26 AM Reply With Quote
The seller should be able to give you the specifications quite easily, such as component manufacturers etc, etc. Once you know these, you could quite easily do the rest yourself and type a specification sheet up. Obviously it involves a bit of work for the seller but to some extent, should be already included in the advert. (That is, if it's been advertised)
Phil
PS. Here is an example of our vehicle specification
[Edited on 14-9-07 by Hellfire]
DarrenW
posted on 14/9/07 at 11:29 AM Reply With Quote
Not sure what you mean by spec is relevant to taking a car to italy. Do you need to fill in a specific form and therefore need certain data?
Im asking in case all they need is engine capacity, age, emissions data etc or if you mean type of engine, any mods, brake system, chassis type, approvals proof, transmission, tyres, wheels, fancy bodywork bits etc etc (as you would see in an advert for such a car.
I dont think there is an official detailed spec sheet in UK. Maybe just one that an owner would create on non-official paper.
copeo
posted on 14/9/07 at 11:49 AM Reply With Quote
i need a document made by the manufacturer with all data of the car, so with all you said: engine capacity, age, emissions data etc or if you mean type of engine, any mods, brake system, chassis type, approvals proof, transmission, tyres, wheels, fancy bodywork bits etc etc
www.allkitcar.com
posted on 14/9/07 at 12:00 PM Reply With Quote
The problem you will encounter, is that a specific manufacturer did not build the vehicle. As you've stated, it's a Locost BEC. Therefore the only manufacturers part that will have more than a few detailed specifications is the engine. The best you can do, is find the engine make and model and serial number and get the manufacturer to send you a detailed specification of the engine.
Phil
copeo
posted on 14/9/07 at 12:33 PM Reply With Quote
many thanks, and are there company that do this document in place of the manufacturer?
www.allkitcar.com
posted on 14/9/07 at 01:30 PM Reply With Quote
In theory the builder/seller or you could say that you are the manufacturer and therefore genertae your own specification sheet for the vehicle.
DarrenW
posted on 14/9/07 at 01:33 PM Reply With Quote
****Post no. 5000!!!!!!****
There isnt anyone i can think of. i know with my engine i sent the engine number off to Ford and they confirmed engine age but nothing else.
With a locost the manufacture is the person who built the car and as such any spec sheet could be generated by them on a computer. With that in mind you could probably do the same if you get the details. The question is wether this would be accepted by the Italian authorities.
All i can suggest is talking to your equivalent of DVLA (or whoever else would be the recipient of your paperwork) and ask them for advice. Im wondering if they may have another form to fill in with respect to amateur built vehicles. Only other option is if their are any people in Italy who have built and registered a locost or similar and find out what they did.
In Uk DVLA has a detailed website for such things and pdf format documents that you can download and submit. Do you have anything similar you can look into?
[Edited on 14/9/07 by DarrenW]
