Author: Subject: Ariel Atom - Front Number Plate
posted on 15/9/07 at 04:40 PM Reply With Quote
Atoms come from the factory with sticky front number plate's on the slanted nosecone.
Is this perfectly legal? I.e. Would you get a similarly designed car through SVA with this?
StevieB
posted on 15/9/07 at 04:43 PM Reply With Quote
You won't have a license plate for SVA because you won't get a reg number until you've passed SVA (at least one thing you won't get tested on!).
posted on 15/9/07 at 04:45 PM Reply With Quote
Number plates are not needed for SVA. However MOT is a different thing. Can't remember offhand but I think number plates have to be vertical . New regulations coming in require the plate to have a B.S. number which sticky fronts will not have = automatic failure!
nitram38
posted on 15/9/07 at 04:52 PM Reply With Quote
A lot of atoms have sticky plates, but most of the new ones have a bracket on their front lights for a number plate, which in this photo is not present!
[Edited on 15/9/2007 by nitram38]
rf900rush
posted on 15/9/07 at 08:35 PM Reply With Quote
Just as a note
When my car was tested a Standard Approved Number plate would of failed if fitted, on radii.
I guess it's lucky that Reg. No.s are issued post passing.
posted on 15/9/07 at 10:40 PM Reply With Quote
Ah... makes sense!
Thanks all.
Vindi_andy
posted on 18/10/07 at 10:33 AM Reply With Quote
as i understand it the numberplate has to be fitted "as near to vertical as is possible"
Delinquent
posted on 18/10/07 at 10:55 AM Reply With Quote
can't remember the details, but on Pistonheads one of the members had found a supplier of BS registered sticky front plates, so they are out there. Obviously doesn't get around the other issues but from that point alone it's a hurdle that can be overcome.
posted on 18/10/07 at 05:11 PM Reply With Quote
Number plates come as the backing (white or yellow) which has the required details and BS number. The digits are applied before the clear plastic cover is applied. If you can get hold of them they may possibly be suitable but they are not self adhesive.
