dirty130
posted on 5/10/07 at 07:58 PM |
Piping support
Hello, I am after a support for my water piping. i wanted to weld on a Y shape bit of metal to the chassis to support the pipe to the water pump (Im
running a 1.6 pinto) A friend said there is a spring bit of metal i can get that will do the job any ideas?
whitestu
posted on 5/10/07 at 08:07 PM |
I used a bit of bent ali strip on my CVH to support water pipes.
Seemed to work OK.
Stu
posted on 5/10/07 at 09:07 PM |
We used LARGE Rubber Insulated Stainless Steel P-Clips... a bit agricultural but they're still on!!!
caber
posted on 6/10/07 at 09:30 AM |
You can get thick plastic coated steel band with holes at about 15mm centres that is used to strap all sorts of pipe on building sites, I have used a
bit for pipes on my car, it is not expensive and available from electrical wholesalers.
Caber
