RickRick
| posted on 8/11/07 at 04:25 PM |
Hazard Lights
Do Hazards have to flash as a full set, or would it be ok sva wise if they were slightly out of syn left to right
Paul TigerB6
| posted on 8/11/07 at 04:45 PM |
running through a single flasher relay - how can they run out of sync???
dan__wright
| posted on 8/11/07 at 04:49 PM |
off the top of my head im sure the manual says they must flash in sync.
FREE THE ROADSTER ONE…!!
John Bonnett
| posted on 8/11/07 at 06:58 PM |
quote running through a single flasher relay - how can they run out of sync???
I absolutely agree, how can they be out of sync with a standard hazard relay.
John
RickRick
| posted on 8/11/07 at 08:06 PM |
i was planning not to use a relay, and LED bulbs, without just adding resistors
iank
| posted on 8/11/07 at 09:19 PM |
A flasher relay actually does the on/off cycle. Were you planning to use two indicator relays, one for left, one for right and running them both at
the same time for hazard? That's not how they are normally wired.
As said I don't think the tester will like non-sync'ed hazards on left/right sides.
Found it in the manual
9.1.7.b in the pdf draft manual.
7. Check the hazard warning device
a. operates with the ignition switched both on and off
b. operates all the direction indicators causing them to flash simultaneously
[Edited on 8/11/07 by iank]
Anonymous
