Author: Subject: Sierra uprights – mushroom inserts - SVA
Paul (Notts)
posted on 11/12/07 at 04:54 PM Reply With Quote
I have sierra uprights on the front with the top wishbone connected to a Mushroom insert that is held in place by a pinch bolt.
Do I need to drill through the upright and mushroom insert and place a bolt through for the SVA or is the above setup sufficient
Paul
worX
posted on 11/12/07 at 05:20 PM Reply With Quote
If I've understood your post correctly then the Pinch bolt is sufficient.
saigonij
posted on 11/12/07 at 05:24 PM Reply With Quote
i have heard conflicting info on this...
i have heard that you need a pinch bolt...
robinj66
posted on 11/12/07 at 05:47 PM Reply With Quote
I've heard that you do need the extra bolt - I just drilled and tapped an M6 thread
Paul (Notts)
posted on 11/12/07 at 05:53 PM Reply With Quote
I have heared conflicting stories so thats why I am asking ....
anyone passed at notts sva with just the pinch bolt?
Paul
bonzoronnie
posted on 11/12/07 at 06:44 PM Reply With Quote
Mushroom inserts
Although I can't provide an answer.
I have given this matter some thought as part of my Roadster project.
Unlike the original Sierra mcpherson strut, the musroom adapter does not have a locating lug.
On the original Sierra strut the locating lug also doubles up as a secondary failsafe. The strut cannot be pulled from the hub assembly whilst the bolt remains intact.
Obviously this is not the case with the musroom adapter. If the pinch bolt became loose ( however unlikely this may be ). The adapter will then be free to be pulled out.
My own view is, it would be a sound engineering practice to provide some means of failsafe.
As others have stated. The easiest way to do this is with a secondary bolt through the casting & tapped into the adaptor.
Ronnie
Paradoxia0
posted on 11/12/07 at 06:53 PM Reply With Quote
Hi Paul
I got through the SVA at Notts with just the pinch bolts. I have been informed though at some test centers you will need to drill and bolt the mushrooms in the uprights too...
Mark
There is no replacement for displacement...
l71300cc
posted on 19/10/11 at 08:40 PM Reply With Quote
insert dimensions
hi mate, if you give me the exact dimensions I can send you a pair through post.
Solid Aluminium that is.
regards,
Albert.
Talon Motorsport
posted on 19/10/11 at 09:50 PM Reply With Quote
For the 30mins it will take you to do the job of putting an M6-M8 bolt through the uprights in to the mushrooms why risk failing the IVA if thats the only thing it fails on?
posted on 19/10/11 at 09:57 PM Reply With Quote
Not sure if its Jesus or Lazarus, but either way, its a resurrection.
40inches
posted on 20/10/11 at 07:29 AM Reply With Quote
As with all things IVA, if in doubt, just do it! If it looks 50/50 why take the gamble?
