Jasper
| posted on 25/1/08 at 02:50 PM |
SVA and steering wheels
Is it ok to use the original old Sierra steering wheel for SVA, as I believe I can't use my Momo on a quick release hub.
And if so, so anybody have a spare horn centre pad as mine is missing?
HAL 1
| posted on 25/1/08 at 02:55 PM |
Yes should be ok, mine had 1985 wheel, 22 years old! passed last year
| posted on 25/1/08 at 03:13 PM |
Just make sure that it leaves enough room for you to get in and move around underneath it - I'm sure someone here got a SVA fail point due to
the wheel impeding the driver's movement.
DarrenW
| posted on 25/1/08 at 03:26 PM |
Yes - my Dad.
I failed cos wheel was too high - i ended up fitting smaller aftermarket one and loweing the column.
Std sierra wheel is highly recommended as long as you have proper control of the ca etc.
| posted on 25/1/08 at 03:47 PM |
it also helps if you have proper control of the keyboard and not miss out the 'r'
| posted on 25/1/08 at 04:22 PM |
Are QR wheels now considered not SVA friendly??? Glad my examiner didn't know that!!
dan__wright
| posted on 25/1/08 at 04:27 PM |
AFAIK they have to be lockable to prevent them being removed while driving.
put the ignition key and release key on a keyring, weld it shut and its not possible to open while ignition is on.
FREE THE ROADSTER ONE…!!
ditchlewis
| posted on 25/1/08 at 04:30 PM |
i used my donor's steering wheel and passed the sva. i am now about to change it, when i can get round to it.
ditch
graememk
| posted on 25/1/08 at 04:53 PM |
i have a sva wheel sva pad and sierra boss i lend out for sva only the cost of postage
your welcome to borrow it, u2u me.
Jasper
| posted on 31/1/08 at 12:30 PM |
Thanks chaps for the responses..... I'll use the Sierra wheel I have, but still just need the centre horn cover if anybody has an old one...
