eccsmk
| posted on 27/1/08 at 01:35 PM |
speedo cover any more advice??
im using the zx12 speedo and the trip switches sit behind the fibreglass which is sharpe edged
and the speedo and rev counter stick out proud of the dash,
would it be ok to stick a perspex cover over it all even tho the perspex would sit 3 to 5 mm proud of the dash??
ill post a piccy when my battery for camera has charged
forgive the mess its half way through and as i can only supervise it isnt my mess !!
[Edited on 27/1/08 by eccsmk]
[Edited on 26/5/08 by eccsmk]
Schrodinger
| posted on 27/1/08 at 02:05 PM |
As long as the perspex has the appropriate radius on it I see no reason why it shouldn't be ok.
If it's behine the steering wheel it should be no problem.
Keith
Aviemore
eccsmk
| posted on 27/1/08 at 03:41 PM |
it is in the centre of my dash so unfortunately only half the speedo is covered by the sva proof area doh
if i put u-trim around the perspex and will that be ok?
thanks again
martin
eccsmk
| posted on 27/1/08 at 10:13 PM |
hows this???
done for me it's just hung in place not fixed yet
Schrodinger
| posted on 28/1/08 at 08:48 PM |
Personally I can't say I like the look but it should be ok, are allof your switches SVA ok?
Keith
Aviemore
eccsmk
| posted on 28/1/08 at 08:51 PM |
the switches to the right are inside the "safe" area.
as soon as it is tested i'll bin the perspex
thank you for your replies you've helped no end
atb
martin
eccsmk
| posted on 26/5/08 at 08:12 PM |
bumpy bump
WanchaiWarrior
| posted on 27/5/08 at 02:07 AM |
perhaps profile shape of perspex to more closely match layout of clocks ??? say, trace a line around clocks, then offset said line by 5mm or so ???
And round edges of perspex.
stuart_g
| posted on 27/5/08 at 07:39 AM |
The easiest way I see of making this SVA proof is to not have the clocks protrude through the dash but to space them at the back so they are flush
with the dash. You can for extra measure, fit the perspex flat on the dash with some clear double sided tape, just make sure that the perspex edges
are radius'd. I think radius depends on the thickness of perspex but not sure.
eccsmk
| posted on 27/5/08 at 04:57 PM |
cheers folks
back to the garage
