rumplitter
| posted on 28/1/08 at 04:14 PM |
SVA brake and clutch lines
I was considering having rally design make me a complete full length brake and clutch lines in braided stainless steel/P.T.F.E. pipe
Cost wise it's no more than me buying a brake pipe kit + copper piping + unions + tools for dong the job in the first place.
I presume I'd just have to have more fixings?
PJH
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
RazMan
| posted on 28/1/08 at 04:18 PM |
Yep, although a solid pipe still needs a fixing every 300mm so no difference really. I used braided flexi lines from mc to caliper and it is much
easier to install, looks good and they work perfectly.
Raz
Richard Quinn
| posted on 28/1/08 at 04:29 PM |
Speak to Russbost on here if you are thinking about getting lines made up.
| posted on 28/1/08 at 05:00 PM |
Theoretically braided lines can still bulge a bit under pressure so copper lines would give a better pedal feel. Not sure how significant a difference
it makes in practice- I suspect very little!!
tks
| posted on 28/1/08 at 07:22 PM |
yupsz thats wy its braided...and not the normal one. f.e sierra front original
Tks
lsdweb
| posted on 28/1/08 at 08:17 PM |
If you're worried about braided hoses 'bulging' and losing pedal feel, just remember what all the top race teams use!
RazMan
| posted on 28/1/08 at 09:51 PM |
I would challenge anyone to tell the difference
Raz
foes
| posted on 31/1/08 at 06:51 AM |
i've used all ptfe overbraid from m/c to calipers, less joints to leak/make up and a friend of mine does a bit of spannering on evo rally cars
which use the same, if its good enough for them its good enough for me...
[Edited on 31/1/08 by foes]
