Author: Subject: Brake Piping Exposed?
cloudy
posted on 12/3/08 at 01:22 AM Reply With Quote
I need to run some brake pipes between the seats on my middy (no trans tunnel) Are there any SVA rules governing protection of brake piping from feet etc I should be aware of?
James
nitram38
posted on 12/3/08 at 05:43 AM Reply With Quote
Put some spiral wrap around it and it will pass.
The sva inspector will look for possible abrasion of the pipe and ask you to put some on if there isn't.
posted on 12/3/08 at 07:39 AM Reply With Quote
You really want to protect it in some way if only for your own peace of mind personally I would use plastic trunking.
Bluemoon
posted on 12/3/08 at 08:58 AM Reply With Quote
I would agree with British trident, why not make a small U section (well top hat type thing) Ali cover that's screwed to the floor you could also run wiring etc in this as well?
Dan
[Edited on 12/3/08 by Bluemoon]
wilkingj
posted on 12/3/08 at 09:41 AM Reply With Quote
Yes... But make sure its secured properly, even in the trunking, or it will vibrate and chafe. This is what the do not want, as it will wear through in time, and then leak, giving rise to a dangerous situation.
Whatever you decide to do in the end, make sure the pipes are secure and cannot move, chafe, rub etc. How you do that is another matter. There are several methods. Use brake pipe clips inside the trunking etc etc.Just lying loose in thrunking will fail just as easily as no trunking at all.
Best Regards
Geoff
http://www.v8viento.co.uk
Mr Whippy
posted on 12/3/08 at 10:26 AM Reply With Quote
Old aircooled vw's have the rear brake line running along the floor next to the tunnel. Held on with 3 bent tabs and living with all the rust, but yet to see any damaged ones or rusted through. I have done the same with the Falcons pipe instead of the usual next to the propshaft.
vindicator
posted on 12/3/08 at 11:09 AM Reply With Quote
get some old rubber piping and make a cut length ways. Cover the brake piping with the rubber piping and make sure that you use cable ties to secure the rubber piping to the brake piping. I had to do with the brake piping around the radiator hoses just in case they touched.
Past SVA no propblems.
cloudy
posted on 12/3/08 at 11:44 AM Reply With Quote
Thanks guys, that's food for thought - I'm generally against wrapping brake pipes as you then cannot check for corrosion. You also risk holding moisture against the tube. I'll come up with some sort of unchafable seethrough foot proof device
James
posted on 12/3/08 at 12:07 PM Reply With Quote
Use Kunifer brake pipe and you won't need to check it for coroision.
DaveFJ
posted on 12/3/08 at 12:24 PM Reply With Quote
I would think you also need to protest it from crushing....
Dave
posted on 12/3/08 at 07:40 PM Reply With Quote
Same as early Golf and Scirroco
I have seen a few of them rust through but the Beetle was waterproofed better
tks
posted on 12/3/08 at 07:53 PM Reply With Quote
i would protect it from impacts...
sow placeing it inside some kind of tube or protect it with a small angle or U allo would be my idea...
in the end you don't want to drop a hamer
or anything wich could just crush your brake tube....
i think personally that i would run 2 boxed section unther the car...
and in between them i would place the brake lines..
in that way you can easyly acces and spot them and the day it leaks it will leave you a mark on your driveing way...
