zilspeed
posted on 15/3/08 at 11:21 AM |
Wonder why it failed SVA
Car on ebay.
I really can't guess from this pic why this car might have failed SVA.
It surely can't be the chicken wire covered alternator sticking out the top ?
graememk
| posted on 15/3/08 at 11:37 AM |
in fairness if i hadnt of come across this site my car would of never passed sva
tjoh84
| posted on 15/3/08 at 11:39 AM |
that what you call build the car around the engine with out changing prob lucky it didnt pass as would get ripped for that
zilspeed
| posted on 15/3/08 at 11:47 AM |
That's Locostbuilders for you though.
The font of all knowledge
tks
| posted on 15/3/08 at 11:53 AM |
I think its the reason...
first where is the radius on that chickenfence??
second its moveing part maybe not enough protected???
Tks
tegwin
| posted on 15/3/08 at 12:01 PM |
There is also a serious lack of any indicators!
www.verticalhorizonsmedia.tv
| posted on 15/3/08 at 12:06 PM |
Shame really - the owner has obviously put a fair bit of effort and money into it, but doesn't seem to have been aware of the SVA requirements
(or misunderstood them).
If only he'd been a member of this forum, he could have avoided all those issues (as suggested above).
whitestu
| posted on 15/3/08 at 01:06 PM |
Is that the dizzy sticking out of the bonnet?
Wonder what engine it is?
Stu
g.gilo
| posted on 15/3/08 at 01:11 PM |
sva fail
looks like a ford v6 to me.
Werner Van Loock
| posted on 15/3/08 at 01:47 PM |
it has indicators, but you can't see them on that picture, they're right under the headlights.
And apparently when he started building he didn't know anything about sva then:
quote: Although the brake performance is good, it needs to be a dual line system. Basically it needs the master cylinder changing. Existing brakes to
each wheel do not need to be replaced. I have a replacement master cylinder that is included.
The hand brake needs to be a cable, not hydraulic.
The steering column needs to be partly collapsible.
There are some bits of trim that need to covered as some parts of the body work are considered too smaller radius !!
[Edited on 15/3/08 by Werner Van Loock]
http://www.clubstylus.be
Confused but excited.
| posted on 15/3/08 at 04:55 PM |
I'd be a bit concerned that he built the car, but doesn't think he has the tools/skill to correct the SVA failure points.
Alfa145
| posted on 15/3/08 at 05:07 PM |
Stu
Guessing from the position of the alternator and dizzy it's an old 3.0 Essex v6
dave1888
| posted on 15/3/08 at 05:25 PM |
Nice looking car though
tks
| posted on 15/3/08 at 05:58 PM |
ask if it has stamped a chasisnumber on already....
James
| posted on 15/3/08 at 07:11 PM |
Will someone post the damned link please!!!
- Muhammad Ali
| posted on 15/3/08 at 08:07 PM |
the reason for the chicken wire is that the builder did not want to go over the £ 250 budget!!
matt_claydon
| posted on 15/3/08 at 11:57 PM |
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320228166311
tks
| posted on 16/3/08 at 04:10 PM |
mhhhh it smells a bit y quote
The chassis number can be any 17 letter and number combination of your choice.
If the car have had a SVA test then there should be already a chasisnumber in the chasis right????
Tks
DarrenW
| posted on 17/3/08 at 04:10 PM |
Tks
Ad states it needs an SVA. It was probs a fail point that he hadnt bothered to get a chassis number sorted before he took it up as well.
£3,000 start - he will be lucky with the way hes worded the ad. It reads like he is totally incoptent and the car is a liability. Would have been
better sayings its an unfinished project requiring finishing off. At least he has been honest i suppose.
Does an SVA fail sheet make it worth more?
DarrenW
| posted on 17/3/08 at 04:11 PM |
Mind you - £3,000 ish for an almost finished ST doesnt sound bad. They are quite a nice looking car when built well - i like the proportions of them.
tks
| posted on 17/3/08 at 09:15 PM |
Tks
Nahh to odd for me how can you apply for SVA without a chasisnumber????
