paulmw
| posted on 25/3/08 at 07:37 PM |
Fuel filler reducer - Size?
Lots of searching on SVA reducers but I couldnt find the required diameter the hole needs to be
I think its 22mm is this correct?
Cheers Paul
| posted on 25/3/08 at 08:01 PM |
IIRC its about 23.6mm diameter.
Phil
Johneturbo
| posted on 25/3/08 at 08:02 PM |
One of these should do it, if you have an aero style cap
https://www.europaspares.com/FUEL_CAPS_and_HOSE/FLANGES__ETC/FUEL_FILLER_CAP_LEAD_FREE_REDUCER___LFF300__2640.html
matt_claydon
| posted on 25/3/08 at 08:13 PM |
It's in the manual, section 15.2 - 23.6mm.
paulmw
| posted on 25/3/08 at 08:16 PM |
Thanks fellas. I was going to try and make one (or specifically get Worx to make one)
I begrudge paying £15 for something that will fall off
matt_claydon
| posted on 25/3/08 at 08:18 PM |
It can of course be smaller than 23.6, as long as you can still get an unleaded nozzle in!
Edit: It's should be a bit less - 23.6 mm is the size of the leaded nozzle so the reducer must be small enough that it cannot be inserted.
[Edited on 25/3/08 by matt_claydon]
bigrich
| posted on 25/3/08 at 09:26 PM |
A sierra rear driveshaft washer stuck in there is perfect, and they fall out afterwards quite easily
