myeates
| posted on 11/4/08 at 01:43 PM |
chassis number stamps
hi all just about to stamp my chassis number on and make a separate plate to rivet to bulkhead but what other information needs to go on the second
plate or is it just the vin number, do i need to include car type and engine number aswel or is that optional
thanks in advance
mark
matt_claydon
| posted on 11/4/08 at 01:54 PM |
Just the VIN; if you want to include anything else it's entirely up to you.
caber
| posted on 11/4/08 at 04:14 PM |
You also need to stamp it "permanently" on the chassis somewhere that MR DVLA can read it. rivited plate no good it has to be on a welded
bit of the chassis or on a plate welded to the chassis minimum 5mm high numbers and letters!
Caber
myeates
| posted on 11/4/08 at 05:04 PM |
great thanks for that knew about the permanent bit but thanks anyway see if i can do them straight
Paul TigerB6
| posted on 11/4/08 at 05:06 PM |
Sorry to hijack the thread but does the chassis need to be stamped for the SVA or just for when DVLA bring their total incompetence to the fore and
sort out registration??
I am going to buy a set of the number / letter stamps later as the car will be done within 2 weeks now so what size is best / legible?? Looking at a
set of 4mm character ones on ebay at the moment so please dont bid against me - the guy only lives 5 mins away from me so i can collect in person -
are these suitable??
linky
[Edited on 11/4/08 by Paul TigerB6]
tks
| posted on 11/4/08 at 05:41 PM |
Caber
Whats your doubt about the 4mm ones???
if he says 5mm it will be 5mm...
just my 2p
Paul TigerB6
| posted on 11/4/08 at 05:47 PM |
Missed the minimum 5mm height post. So thats a legal requirement then??
tks
| posted on 11/4/08 at 06:17 PM |
if he states it it will be that not???
else wy the minimum
p.s. don't try to be rude just a bit clear
its weekend anyway
Valtra
posted on 13/4/08 at 10:31 PM |
Any rules on the length of the string of numbers or any ie as it's my first chassis how about vin . 001 ? (not going to do that just wondered)
myeates
| posted on 14/4/08 at 06:56 PM |
between 9 and 17 digits i think
Valtra
| posted on 14/4/08 at 08:08 PM |
yea saw in the total kit car sva roundup on-line that it's at least 8 and the norm for production cars is 17
cheers
smart51
| posted on 14/4/08 at 08:48 PM |
Another thread hijack. For a scratch built car, when do you make up the VIN / tell the DVLA? Application for SVA? Application for inspection?
I'm almost done with the chassis and would like to weld in the stamped plate before I finish, but obviously don't want to apply for an SVA
yet.
btw: my MNR has its VIN stamped on the aluminium scuttle panel which is glued and riveted to the chassis. Not welded at all.
