CRAIGR
| posted on 17/4/08 at 08:04 AM |
Handbrake light
Is a handbrake warning light now a requirement for sva or is it still just a level test switch and light.
speedyxjs
| posted on 17/4/08 at 08:07 AM |
Im pretty sure you do need a handbrake warning but could be wrong
| posted on 17/4/08 at 08:10 AM |
Next post down from MNR about the digidash clarifies the point.
[Edited on 17/4/08 by coozer]
Paul TigerB6
| posted on 17/4/08 at 08:11 AM |
Its always been a requirement for SVA to have the brake warning lamp - just now the symbol has to be on the face of the lamp itself.
as per here
If you wire up a live feed to the lamp and then have two paths to earth, one via the handbrake switch and one via the fluid reservoir cap if you have
a test facility then you are safe.
CRAIGR
| posted on 17/4/08 at 08:16 AM |
Always been a requirement to have a brake fluid level warning lamp but not sure about handbrake.
The post ref the digidash i take to mean that if it does have a handbrake warning light it must have the correct symbol on the light
itself.quote: Originally posted by Paul TigerB6
as per here
graememk
| posted on 17/4/08 at 08:35 AM |
i dont have one on my hand brake i have a fluid test lamp on my dash, the handbrake switch is only there to test the bulbs working
| posted on 17/4/08 at 08:41 AM |
As above - the handbrake switch is just a convenient way of proving that the brake fluid warning light is OK. A push-button would be ok, although you
should remember to use it occasionally (!) or, if you're feeling really geeky, you could wire up a simple IC like a 555 timer and get it to
light the lamp for 5 seconds when you turn on the ignition.
Only the brake fluid warning light is a SVA requirement.
graememk
| posted on 17/4/08 at 08:45 AM |
well to be honest, i've taken the switch off the dash now, i wired it to the starter motor so it flashes on when i crank the indy over.
