RJK350
| posted on 21/4/08 at 08:52 PM |
BEC Reverse
Hi I'm in the early stages of building an MK Indy with an Aprilia engine. I see the SVA requirements are changing on a reverse gear requirement.
Can any please help on the best solution e.g. Quaife, electrical reverse etc. and if so is there some photos or look at.
Thanks Rob
Dangle_kt
| posted on 21/4/08 at 09:00 PM |
I read that the IVA is not coming in till May 2009, thats a year to get it tested.
All the electronic ones I;ve heard about have been marginal, and the quaife whilst very good are pricey!
StevieB
| posted on 21/4/08 at 09:01 PM |
As said, the best solution is to get it finished and tested quicker
jlparsons
| posted on 21/4/08 at 11:50 PM |
I've been looking into this and I've concluded that a mechanical reverse is less reliable, heavy and power sapping. These factors seem
very much at odds with the BEC ethos.
In my opinion the best solution is to modify your engine controller (say a megasquirt) to divert the throttle position sensor output to a speed
contoller (when reverse is engaged) to control an electronic reverse. As I happen to be married to an electronic engineer this is on my to-do list!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
fesycresy
| posted on 22/4/08 at 07:50 AM |
It'll be intersting to see the criteria for the reverse test.
Watching some electric reverse's go back over a 40mm block can be entertaining !
The AB Performance one is supposed to be good though.
Kriss
| posted on 22/4/08 at 12:06 PM |
I have gone for the eletric option. I do not plan on using it alot, only for swinging into a pub carpark space really.
Chris (zxrlocost) is installing the AB kit into my MK. I will let you know how I get on with it
RJK350
| posted on 22/4/08 at 07:17 PM |
Thanks for all your help
tks
| posted on 22/4/08 at 08:17 PM |
i build an electronic controller to be able to manage the speed...
does the AB one that to???
or is it flick the button and press the brakes  ...
Tks
paublo999
| posted on 28/5/08 at 03:54 PM |
Kriss
any news on your electric reverse m8?
would love to see some picks
anyone else found any good photo's to pinch ideas from....
Paul.
jacko
| posted on 29/5/08 at 06:13 PM |
Can a electric mover that fits to caravans be adapted
