rumplitter
posted on 28/4/08 at 07:08 AM |
fuel Cap SVA compliant?
I noticed in a Europa advert that they sell a lead-free reducer, which fits into aero-caps to allow lead-free nozzles only.
Is this required for SVA?
I have a fuel cell which has quite a wide neck.
will it not be SVA complaint?
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
Mr Whippy
| posted on 28/4/08 at 07:11 AM |
if your car has a cat then you need one
one wonders where you are suppose to get 4 star leaded these days? Haven’t seen it in years and years.
[Edited on 28/4/08 by Mr Whippy]
RazMan
| posted on 28/4/08 at 07:46 AM |
You can get away with just a large washer plonked inside the filler neck - as long as it prevents the entry of a 4 star pump nozzle it will pass SVA.
Raz
jabs
| posted on 28/4/08 at 08:04 AM |
real 4* leaded is available at one garage in Harrogate but is is very expensive, I think it is over £2 a ltr
worX
| posted on 28/4/08 at 11:43 AM |
Not in every SVA test station you can't!
Even though the washer was turned to fit, wedged in and measured perfectly!
Not seen the europa one, but I think you can get one for as little as £3 or £4...
