scotty g
| posted on 29/5/08 at 04:18 PM |
Cat needed or not?
Hi all,
I'm using a 1.8 Zetec from a 1993 Mondeo, I am planning on using the existing injection set up and the existing engine wiring loom/ECU.
Now when all this was still in the Mondeo it worked with a Cat so will I need a Cat in order for it to work properly even though the engines age says
i don't need one for the SVA?
Cheers guys.
imp paul
posted on 29/5/08 at 05:53 PM |
o yes Ginger cats are very cool oops sorry yer you will need a cat for sva so im told
big_wasa
| posted on 29/5/08 at 06:21 PM |
Not saying your wrong but why ?
it will need the Lambada to run closed loop but the cat sits after this.
emisions should be much better than say the same pre Aug 95 zetec on webers.
[Edited on 29/5/08 by big_wasa]
scotty g
| posted on 1/6/08 at 09:52 AM |
Hmm.
So thats 1 yes and 1 are you sure.
I was pretty much thinking No but thought it best to ask, now I'm all confused. Anyone else have any thoughts on this.
Luckily I'm not quite at the stage where I will be fitting the exhaust system so it might be worth bunging a cat on anyway?
