eddbaz
| posted on 21/7/08 at 11:18 AM |
intigrated stop/tail light
Can a combined stop tail light be used for sva,I brought a combined hella led stop/tail light with an indicator outer ring,but someone has mentioned
that for sva the tail and brake lights have to be seperate,can anyone throw some light on this as I want to cut holes in my rear arches for the
lights.
Ed.
graememk
| posted on 21/7/08 at 11:20 AM |
i might be wrong but i think its the fog light that cant be next to the stop or tail light.
edit
yeap i'm right stop and rear light ok together fog lamp must be 10cm away.
[Edited on 21/7/08 by graememk]
eddbaz
| posted on 21/7/08 at 11:29 AM |
The reason I posted the question was because of the following replies that I had from a previous thread on hella lights
Originally posted by eddbaz
Hi phil,
I've brought the same light unit,a combined stop and tail light with an indicator outer ring, I am right in thinking that this is all I need and
only need to fit one unit per side,I'm a bit worried now seeing that you have two on each side,canm you tell me what the lights are on
yours,cheers
Ed
(i said the silly questions would keep coming)
Ed,
I was going to use this combo initially but if you need an SVA test it wont pass using the LED as tail and stop - they need to be separate lights. (I
was told this first hand by a tester at Beverley).
Chris.
[Edited on 21/7/08 by eddbaz]
mackei23b
| posted on 21/7/08 at 11:30 AM |
Mine passed with combined stop tail.
But the fog light must be at least 10cm from the brake light
RazMan
| posted on 21/7/08 at 11:38 AM |
I think that tester must have been drinking
Combined stop & tail lamps are perfectly ok - just keep the fog seperate.
Raz
Nosbod
| posted on 21/7/08 at 11:51 AM |
I was told by SVA man that a combined stop and tail is only acceptable if a different set of LED's are used (within the light) for stop and
tail. The s-v-c's ones i have use the same LED which come on brighter for stop. Same prinicpal as a filament bulb i guess - they are ok
combined in one bulb as such, so long as separate filaments.
I wont be risking it using them combined.
It might be worth a visit/call to your local SVA for peace of mind - thats what i did.
iscmatt
| posted on 21/7/08 at 01:29 PM |
Mine passed with the exact same lights. (Notts SVA centre). I was told that you cannot use the same BULB for the rear tail/brake because if the
filament goes you've not got either, but there was something about LEDS that are different and so do not have the same issues. (ie - the LED
ring can do both jobs and pass)
But as i say, passed no probs
(lights are an interesting one for me as i also have the small headlights upfront which everyone always say will fail but again i had no issues with
them either, the beam pattern was spot on.)
Nosbod
| posted on 21/7/08 at 03:46 PM |
I guess the only pattern emerging here is that the SVA centres have different agendas when it comes the lights.
Looks like Notts might be the place for the test! (even though i only live 2 mins from the SVA centre in Beverley).
COREdevelopments
| posted on 21/7/08 at 06:23 PM |
what a load of bull! stop/tail light is perfectly acceptable for the sva. its used on loads of production cars, think your getting confused with fog
and tail lights? if your sva tester has a problem with stop and tail lights being used together then he needs a refresher course in sva!!
atb
rob
