heyzee
| posted on 19/12/03 at 06:39 PM |
donor vin plate
what happens if your donor doesent have a vin plate or the vin plate is lost,can you still get a age related plate or not????
stephen_gusterson
| posted on 19/12/03 at 07:46 PM |
donor vin isnt used on the kit car
you need a v5 to prove a single donor not the vin plate
atb
steve
heyzee
| posted on 19/12/03 at 08:17 PM |
vin plate
so if i have the v5 for the vehicle im useing as a majority donor i dont need the vin plate for that car at all,its just i was told id need the donors
vin plate
Mk-Ninja
| posted on 19/12/03 at 08:51 PM |
Heyzee, I think that people in general suggest that you get as much evidence as possible to confirm the donor but as Steve says its the V5 that
matters.
Gordon
I'm sure I've got one, just don't know where I've put it
| posted on 19/12/03 at 08:55 PM |
ditto. i chopped out my vin plate just incase i needed it, it could easily have ended up in the scrappers though.
stephen_gusterson
| posted on 19/12/03 at 10:43 PM |
i also kept my vin plate - more out of souvenir than necessity.
v5 is all you need
atb
steve
muffking
| posted on 24/12/03 at 10:24 AM |
Just to add to te original question. What if the engine doesn't match that of the V5. Can you still vere away from a Q-plate???
http://homepage.ntlworld.com/l.esberger/
Mk-Ninja
| posted on 24/12/03 at 02:20 PM |
All you have to have is two major components from thier list. Im building a BEC and still hope to have age related plate.
Gordon
Mk-Ninja
| posted on 24/12/03 at 02:25 PM |
Just to expand a bit, you need two from the following for an age related plate.
Suspension (Front And Back)
Axles (Both)
Transmission
Steering Assembly
Engine
Hope that helps
Gordon
