Adam
| posted on 14/8/08 at 07:06 PM |
Nottingham SVA Good Fail (If There's Such A Thing)
Took the car for and SVA yesterday. Got there this time (Previous post ... I Broke Down ) I thought the car would fail on emissions , noise
and the speedo. I didn't have chance to get it to the local garage to check the emissions so was very surprised when it passed. It was right
on the limit with the noise level but scraped through. The speedo was spot on... well out by 1mph Failed on a couple of things...bit annoying
really. Here's a list:
MK Nose cone back edge - Radius
SVA friendly headlamps....no so SVA friendly... radius edge
MAC 1 Dash... passenger side back edge, needed U trim on.
Back edge of the Steering cowl needed U Trim on.
And last was the fuel tank breather... needed a loop in it.
All in all was very happy and it's going back tomorrow to have the bit's re tested. Martin at the test center was spot on, really helpful
and offered great advice.
So hopefully should be on the road in a couple of weeks
Adam
Bluemoon
| posted on 14/8/08 at 07:09 PM |
Why the loop in the breather (migh be somthing I'd better do..)
Dan
Ben_Copeland
| posted on 14/8/08 at 07:12 PM |
Good luck with the retest. Strange about the "SVA" headlights !!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Adam
| posted on 14/8/08 at 07:15 PM |
"Why the loop in the breather (migh be somthing I'd better do..) "
He said if you over fill the tank there was no way of stopping the fule coming out the breather. You can fit a one was valve in it but he said this
was the easiest/cheapest way of doing it. The loop acts like an Air trap.
Adam
adithorp
| posted on 14/8/08 at 07:25 PM |
Should be easy fix. Good luck with the retest.
adrian
http://jpsc.org.uk/forum/
DRC INDY 7
| posted on 15/8/08 at 02:56 AM |
Back edge of the nose cone just needs a little rub down with emery cloth to create a 2.5mm radius about 15secs rubbing each side i had to do that on
the day of my test
Like you say they are very helpfull im just glad i took everything plus kitchen sink on the day to cover the bits that i missed ps i had to trim the
mk dash which is same as mac1 dash lower edge on the passenger side
Puddle Dodgers Club
richardh
| posted on 15/8/08 at 06:58 AM |
or you could get a 1 way fuel breather and put that on the end of the pipe. not cheap though
DarrenW
| posted on 15/8/08 at 08:37 AM |
Adam
Very cheap 1 way valve is the ones used in aquariums. People who use air stones and little air pumps have to fit them on the main air line into the
tank. If the pump ever stops the tank back siphons and empties obviously making a mess and killing the fish. The valve will be no more than £3, small
plastic bodied affair with ball inside. I fitted one high up under back panel.
