simonk
posted on 13/9/08 at 10:52 AM |
URGENT SVA HELP NEEDED !!
Hi All
Have been a muppet and need to source / buy / borrow locally for SVA on Tuesday (so by Monday night !)
2x 12mm fine (1mm pitch ?) nuts for seatbelt floor bolts, and
an electronic three pin flasher relay / unit suitable for running LED indicators
Am based Beds / Cambs / Herts borders
Any help gratefully received !!
Simon
speedyxjs
| posted on 13/9/08 at 11:03 AM |
Sorry, cant help you out with the parts but good luck with SVA
| posted on 13/9/08 at 11:16 AM |
Try ringing Namrick re the bolts. They post pretty quickly. Might arrive Monday.....
Good luck otherwise!!!!!
If all else fails use a normal flasher relay and some relays...
matt_claydon
| posted on 13/9/08 at 11:56 AM |
Sorry if this is a stupid question, but are you sure they're M12 Fine? Almost all standard belts are 7/16" UNF (11.11mm).
simonk
| posted on 13/9/08 at 12:49 PM |
Not at all a stupid question - been caught with metric equivalent guessing before...
I'll try 7/16 UNF too and see what happens
Simon
simonk
| posted on 13/9/08 at 12:55 PM |
Yes, measures at 7/16 UNF - thanks, will try them.
Simon
stevebubs
| posted on 13/9/08 at 01:43 PM |
Think Burtons may still be open if you're quick....
simonk
| posted on 13/9/08 at 09:46 PM |
Thanks all for your suggestions - I have sorted the harness nuts from a proper old fashioned local hardware store in Biggleswade. Goldthorpe's
on London Road - can't recommend it highly enough. Took one look at the bolts and wandered out with the correct nut first time. Also had in
stock several different sizes of number and letter punch set so was able to sort out my VIN today as well.
Just need to sort out the fast flashers and I'm there. If I can't get the right flasher sorted I will wire up an extra bulb or two with
the flasher to up the load - should work I suppose.
Thanks all
Simon
Macbeast
| posted on 14/9/08 at 06:08 AM |
Halfords have a range of flashers - just pick suitable one off the shelf. I think I went for a 10A one.
Edit
Oh you have low current bulbs. Any electronic flasher will do then
[Edited on 14/9/08 by Macbeast]
wilkingj
| posted on 14/9/08 at 09:31 AM |
I have a spare Hella electronic flasher. If not, I have some spare bulbs you can wire in.
I'm at home all day. Can pop over if you need.
Best Regards
Geoff
http://www.v8viento.co.uk
Vindi_andy
| posted on 15/9/08 at 10:08 AM |
if you are using LED indicators you probably need a dropper resistor as the LEDs dont draw enough current for the older relays hence why they flash
fast
Macbeast
| posted on 15/9/08 at 10:58 AM |
Not a dropper resistor, but a resistor in parallel, which I think he knows anyway since he is talking about lamps in parallel.
By far simplest is Halfords electronic flasher unit. £5 ish
[Edited on 15/9/08 by Macbeast]
