Author: Subject: Transport to SVA
marmot0
posted on 13/9/08 at 03:18 PM Reply With Quote
Transport to SVA
Can anybody recommend a reliable transport company in the south east london area so that I can get my car to SVA,
It is only a few miles, Cheers !!!!!
posted on 13/9/08 at 03:21 PM Reply With Quote
drive it!
marmot0
posted on 13/9/08 at 03:28 PM Reply With Quote
Did not think it would take long for someone to suggest that.
Test will probably be end of October so probably wet. Not sure I fancy driving a BEC for the first time in the wet through London
smart51
posted on 13/9/08 at 03:42 PM Reply With Quote
My SVA was in December. I drove it there. Wrap up warm.
stevec
posted on 13/9/08 at 03:52 PM Reply With Quote
Mine was November. Go on drive it. The testers like it if you drive there it shows confidence in your build.
Insurance may be a pain if you insure on a chassis number, some only give you 30 days or less! If you fail and take longer to get it registered you may loose a lot of money.
Good luck.with the test.
RoadkillUK
posted on 13/9/08 at 04:30 PM Reply With Quote
We went to Beverley SVA from Bradford 3 times, a good 30 mile drive, each way. It was November and it rained.
It was a lovley drive, a bit wet but ... but nothing, it was only water
[Edited on 13/9/08 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
marmot0
posted on 13/9/08 at 04:42 PM Reply With Quote
Driving it is then,
whitestu
posted on 13/9/08 at 05:27 PM Reply With Quote
Which test centre are you going to?
Stu
marmot0
posted on 13/9/08 at 06:11 PM Reply With Quote
Hi, I need to get from Lee to Mitcham, a grand total of 10 miles.
Thinking about it not sure I want to run the engine for too long on a lean Map
