Author: Subject: things i may fail on?
eccsmk
posted on 1/10/08 at 08:26 PM Reply With Quote
will i fail ?
i have 2 flick switches
1 for side lights only
the 2nd for dip and main beam but its an on/off/on switch
also my battery terminals are not fully covered
i think thats it for now
again thank you in advance
[Edited on 1/10/08 by eccsmk]
martin1973
posted on 1/10/08 at 08:48 PM Reply With Quote
mines the same, use some heatshrink over the ends of switches to smooth the ends off
passed without hassle
martin
eccsmk
posted on 1/10/08 at 08:53 PM Reply With Quote
beautiful
blakep82
posted on 1/10/08 at 09:02 PM Reply With Quote
i wish they were the only things i had to worry about
i've got doors without hinges or latches (clipped in place... hopefully seen as 'removable side panels)
centre bar down the windscreen (move your head either side of it from the seat and you don't actually lose sight of the rivets in the garage door)
not sure about the seatbelt mounts as they don't go all the way through the tube so are not welded both sides (but the manual only talks about this requirement for threaded bushes. my eye bolts are just welded staright on)
in summary, you'll do fine
________________________
