Author: Subject: Reg doc has wrong model - where do we stand?
geoff shep
posted on 12/10/08 at 10:20 AM Reply With Quote
What's the score with buying something like THIS (Ebay Sumo) which THIS site says is a registered as a Cortina:
Vehicle Registration Mark (VRM) tpu650r MANUFACTURER FORD
MODEL CORTINA GL
Transmission & fuel type PETROL
Body type CONVERTIBLE
colour RED
I guess part of it has been changed at some stage, unless the donor was a convertible!
Paul TigerB6
posted on 12/10/08 at 10:31 AM Reply With Quote
Potentially will require an SVA to get it correctly registered!! As it stands it is incorrectly registered and the owner could be fined!!! Also, the insurance could be invalidated until it gets sorted out.
Knock at least £1000 off the value i recon!!
[Edited on 12/10/08 by Paul TigerB6]
posted on 12/10/08 at 10:54 AM Reply With Quote
I think you can download the SVA application forms
There was a period of grace when incorrectly cars could be correctly registered without SVA but I think it ended half a decade ago!!! Can't imagine MOT would be easy without a MOT tester seriously on your side.
posted on 12/10/08 at 10:57 AM Reply With Quote
Personally, I wouldn't trust the car data checker. I'm not saying that it's incorrect but speak to the owner of the vehicle, ask him if it's correctly registered, has had an SVA and what the Model and Manufacturer is stated as on the V5C.
SVA came into force on 1st July 1998 and there's some good guidance on Total Kitcar but speak to the owner first.
Phil
[Edited on 12-10-08 by Hellfire]
zilspeed
posted on 12/10/08 at 11:14 AM Reply With Quote
The second link brings my car up incorrectly as well. I have the V5 here and it says Sylva Leader, that site says Vauxhall Viva.
If you type TPU 650R into the DVLA checker and put make as Pilgrim Sumo not just Pilgrim it comes back fine.
My Sylva is the same - according to the DVLA the make is Sylva Leader.
Not so bad in other words.
joneh
posted on 12/10/08 at 12:27 PM Reply With Quote
A cobra replica with a Pinto!
Wrong wrong wrong wrong wrong....
geoff shep
posted on 12/10/08 at 05:01 PM Reply With Quote
Good point zilspeed, I should have checked that, mine comes up as a sierra but my V5 is correct.
Bigheppy
posted on 12/10/08 at 05:57 PM Reply With Quote
My Magenta comes up as 'other type' and my tin top, owned from new,comes up ok, but both have warnings of other info. Should I be worried. Is it just a ploy to get you to have a data check for £19.99.
Ninehigh
posted on 12/10/08 at 07:17 PM Reply With Quote
What is it a different model on the V5? Should be able to sort that out no problem, when my brother bought his car it was registered as the bigger version and he must have been able to change it easy enough or he would have proper moaned about it. The bizarre thing is he bought it second hand so the original owner must have had it wrong for 3 years!
posted on 13/10/08 at 05:32 PM Reply With Quote
Just put my tintop in and it listed no information whatsoever for it; no manufacturer, no model, no colour etc. It still said "Warning" under other information though
