StevenB
| posted on 13/10/08 at 11:32 AM |
Fuel lines
Is it ok to run the fuels lines with the
P clips rivetted to the ali floor pan
and not the chassis?
And
Is there an accepted position for where
the copper / rubber junction should be
on the front bulkhead?
Side etc?
Flow and return needed for Zetec on TBs.
S
tegwin
| posted on 13/10/08 at 12:07 PM |
Provided the floor is not going to flex too much then you could happily rivet the hose to the floor.... I would rather have it on the chassis
though....Far more secure....(its a mental thing)..
As for flexi/solid joint... I dont think it matters where it is, just make sure that, if the joint fails the fuel wont be pumped onto anything
hot/electrical
www.verticalhorizonsmedia.tv
| posted on 13/10/08 at 02:04 PM |
I wouldn't.....
The ali floor will flex.
Copper gets brittle pretty quickly if it's flexed (I'm assuming you're going for copper fuel lines here)....
iank
| posted on 13/10/08 at 02:48 PM |
If close to the edge of the floor where it's riveted to the chassis then it won't really flex and should be ok (IMO, SVA testers may
choose not to agree).
However it implies the lines are the lowest point on the car. Having grounded a car (hired sierra estate no load in back, big speed bump, unwise
velocity over said bump) and crimped the fuel line running under it I'd avoid it - especially if you are planning to run low to the ground. Is
there no room in the tunnel?
Anonymous
StevenB
| posted on 13/10/08 at 04:21 PM |
I did actually mean inside the tunnel. Sorry for not being clear.
It just means I dont have to bend around tunnel box section uprights etc.
s
IDONTBELEIVEIT
| posted on 13/10/08 at 05:33 PM |
westy megablade ran mine in tunnel p-clipped every 200mm or so HTH
Are We There Yet, Are We There Yet!!!!
